跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Wifi antenna connector broke of completely
I broke of the wifi connector during a repair. Yes, I know i was not careful enough. And it came even worse, when trying to fix it, the soldering iron was too hot, so it snapped off completely. And there was no connection of the middle pin visible. Is there any chance to rescue the wifi? Does anyone has an idea where the middlepin is connected to the mainboard. Is it via multilayer? I scratched of some of the coating, but i can't see any connecting point for the middle pin. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
here is an image of connected components
这个答案有帮助吗?
得分 3
11条评论:
Thanks a lot. Is U3710 beneath the silver cover sitting right of the connectors?
完成的
Great! And is silver cover is easy to detach?
完成的
@denniswienecke im not sure tbh i havent worked on 1 of them boards yet
完成的
do you know if the connection between the two points and the connector is on a sub level? It doesn't look like it going on the surface?
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Dennis Wienecke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 52
