Why is my laptop producing no sound
My laptop does not produce any sound even when at full volume. It is not on mute and I've tried troubleshooting and updating audio drivers
Hi @alvin37808
Check in Control Panel → Sound → Playback and check if the Realtek digital output is enabled.
If not click on the entry → Properties → Device usage → select Use this device (enable) → Apply
这个答案有帮助吗?
It's possible the cable to the speakers became loose or torn inside the case disassembly would be needed to clarify the problem
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 81
2条评论
Hi @alvin37808,
Can you hear sounds when using headphones plugged into the audio connector on the right hand side of the laptop?
由 jayeff 完成的
Hi @jayeff,
Yes I can hear sound from the audio connector
由 Alvin 完成的
