跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
If the caller can't hear me, is it an earpiece problem?
As I was speaking to someone on the phone, they weren't able to hear me mid-conversation anymore, but I was still able to hear them clearly. I checked to see if I may have pressed the mute button, but that wasn't the case. The speaker and sound works perfectly fine with other applications such as voice memo, just not when it comes to calling. A few days later, when someone called, a crackling/static noise started to appear. Does anyone know how I can fix this?
I went to to the apple store to see if they could help. All they did was take a led flashlight, looked at the part where you insert the charger in, and said that there has been some water damage and that the only thing I could do is replace the whole phone itself -.-
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
try voice memo..your problem is not the speaker, it is the mic so using voice memo will show if that is working or not. if apple think there is water damage to the charger then you may have to replace that part which also holds the mic and speaker..
完成的
添加一条评论
2个答案
已选择的解决方案
iPhone 4 Dock Connector Replacement this is the part you will need if voice memo doesn't show any sign of recognising noise/voice.
这个答案有帮助吗?
得分 2
1条评论:
My voice memo seems to be working fine. Any other solutions?
完成的
添加一条评论
The iPhone 4 has 2 microphones - one at the top and one at the bottom. If you are getting sound during videos, on loudspeaker and boice memos the top (noise cancelling) mic is working.
If noone else can hear you during a phone call it is the bottom microphone that needs replacing which is indeed part of the complete dock connector
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fatima Shariff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 6,723
