跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
211 个问题 查看全部
Need some help troubleshooting liquid damaged 2019 MacBook Pro 16 inch
Bought this used liquid damaged 2019 MacBook 16 inch($50.00) , would like to learn how to properly test and fix this sort of problems. Have already taken apart and clean up the logic board and reassemble. Getting a reading on the Satechi USB-C power meter or 5.10V and 0.01A. If anyone could provide some further troubleshooting steps would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Well. First thing is first. You're stuck on 5 Volts and drawing almost no current. Have you made sure that this isn't an issue with a bad part? I see it's back in the housing for this picture. These newer Macs can be weird about booting when some peripherals are not connected, but I would disconnect anything not vital for the Mac to boot and see if that changes anything.
Really the only things here I would consider necessary are the USB C boards (known good ones if possible), and maybe a battery (but only because these can be weird about booting when one is not connected). A display is nice as well if fans are disconnected so you can see if it's booting.
Unless you know it's a board issue already (you didn't mention any other troubleshooting steps). Where was the liquid damage you cleaned up?
这个答案有帮助吗?
得分 3
1条评论:
Hi Alisha C
The only troubleshooting steps I have perform thus far was taking it apart and cleaning the logic board really good with 99% alcohol, I inspect visually the board, can not see anything burned or corroded. I waited 5 days before putting it back together to be sure, but the reading of the sate chi power meter is the same as it was before I took it apart, so nothing has really change on that regard. Liquid damage was water. Liquid damage was located near the usb-c ports for sure. I thought about buying new ones and getting them replaced but was wondering if there is a way to test them? maybe with a multimeter?
完成的
添加一条评论
添加你的答案
Macmod 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 27
