跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
MacBook Pro won't go into recovery mode.
I was given a Macbook Pro 2015 (A1502). It will not go into recovery mode. I'd like to wipe the hard drive and re-install the OS. I have tried command + R numerous times. I've plugged in an external keyboard, no luck. Some of the keys are damaged so I suspected that one might be sticking. When I run the keyboard viewer no keys are being pressed.
How do I get this Macbook into recovery mode?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Do you have access to a second Mac system?
If you do you can create a bootable USB thumb drive OS installer from it. They using it you can wipe the drive and install a fresh copy of macOS onto your system..
First reformat the USB thumb drive to GUID and a Journaled file system.
Access the desired OS installer from here: How to download and install macOS. The highest you can goto is Monterey 12.7.2 with some limitations!
Copy the installer to the thumb drive, then follow this Create a bootable installer for macOS to convert it to a bootable drive.
这个答案有帮助吗?
得分 1
5条评论:
I did create a bootable USB drive with the OS, but how do I boot to it if the keyboard isn’t functioning properly? Holding the option key on startup does nothing.
I suspect the keyboard is giving phantom inputs, so plugging in an external doesn’t help.
完成的
@jlaffin - do you have a USB keyboard? Plug it in that should do it. If not you may need to setup the system is clamshell mode using an external monitor with the lid closed
完成的
I tried my Magic Keyboard plugged in with Lightning cable. Held command R, still nothing, it just boots up to desktop.
完成的
@jlaffin - plug in a external display and close the lid to go into clam shell mode.
完成的
Clam shell mode worked. Thanks very much for the help!
完成的
添加一条评论
添加你的答案
Julian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 224
