跳转到主内容
加入维修社区 - 创建账户
The Xiaomi Redmi Note 10S is a mid-range smartphone by Xiaomi released March 2021. It has a 6.43" AMOLED display, a 64 MP main camera, a side-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Mediatek Helio G95.
Wifi doesn't connect automatically!
When I press the wifi icon it doesn't work until i go to wifi settings and keep refreshing the page! I've struggled with this problem although i updated the phone whenever an update is available
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @otamendy99,
Does activating the WiFi work OK if you start and use the phone in safe mode?
完成的
@jayeff wow i just tried and it works fine but what should i do to make it good in normal mode?? help
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @otamendy99
If it works OK in safe mode but not in normal mode then usually a downloaded app is the cause of the problem.
A downloaded app is one that you downloaded and installed on the phone and wasn't pre-installed on the phone when you first got it.
You will need to uninstall each downloaded app one by one, and test the phone in normal mode between each uninstall to find out if the WiFi activates OK or not. When it does then the last downloaded app that was uninstalled was the culprit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Otmnndy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 260
