跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
How do I get true tone to iPhone 11 pro max without original screen?
So when i answer calls my iphone 11 pro max screen is going black and i think the broblem is with true tone because the phone doesnt have true tone. so how do i get true tone to iphone 11 pro max without original screen?
Update (12/09/23)
Some extra context. The original screen was broken and it was replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
When you answer a call and put your phone to your ear, the display is intended to go black so you don't press buttons onscreen with your face while you're talking. But if it goes black before then, I am more likely to think this is an issue with the proximity sensor. It could be that the phone thinks it is close to your face, even when it's not.
True Tone is to some extent also related to sensors on the same cable, specifically the ambient light sensor, but I would look into replacing the front facing sensor cable. Be aware that this will disable Face ID unless the components that are tied to Face ID are moved over to the new cable since that's where the sensor for proximity lives.
A little history of the device may help the specifics (why doesn't it have the original screen, what happened that it needed to be replaced?)
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kokki 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 279
