跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
210 个问题 查看全部
Does the screen replacement come with the display cables?
As the title asks: does the screen replacement come with the display cables? I'm supposing / hoping so, as I inevitably damaged the screen during a battery swap, and also managed to snap one of the display cables. So: ideally the screen replacement comes with the display cables as well...?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey there @davidaaltman!
If you're asking about the ifixit screen, then yes, it does appear to come with the display cables, as you will see if you flip to the second image in the attached link. There also appears to be a small connector, with no cables attached, at the bottom of the screen.
Also, according to a notice on the page, there are two different types of surface displays that are not compatible and the only way to tell them apart is to closely inspect that connector. I haven't ever done any repairs on a Surface, so I don't know if there is a cable that connects to that connector or if it interfaces directly with your motherboard. If there is a cable, and that one happens to be the one you damaged, then you may have to resort to looking on eBay to find that cable.
Hope this helps!
Surface Pro 4 (1724 v1.0) Screen图片
产品
$159.99
这个答案有帮助吗?
得分 0
1条评论:
Thanks, @fixer85785! I might be missing the detail in the image to which you've linked - which is the item I was asking about, and I apologize for not linking it myself - as I only see the connector and not the cables. But I think maybe I'm misreading your statement and you're confirming that the screen has connectors in general, and I had more intended to ask if the purchase of the screen from ifixit supplied the cables.
Anyhow, thank you for the reply, the reminder about the pin difference, and the suggestion to pick some cables up from elsewhere; I believe I will do just that. Thanks!
完成的
添加一条评论
添加你的答案
David A Altman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 48
