The status indicator light is on once connected to power
My mac mini i7 cannot send video signal to monitor (black screen). I found the indicator light will immediately on (white) once I connected this Mac mini to power. Press the power button for 10 seconds, I can turn off the Mac min and the light also turned off. the light will be on if unplug and replug in .
2条评论
Have you tried anything specifically yet to fix this? This could be as simple as a bad cable. How are you connecting your Mac to the monitor?
由 Alisha C 完成的
I have two Mac mini, the other one is i5 I used the same hdmi cable. mini i5 is working well. I connected this working min i5 to the same power supply, the indicator light won't turn on until I press the power button.
由 yuan 完成的
