跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
476 个问题 查看全部
Screen turning on after screen replacement
I've just replaced the screen on my iphone 11 and everything is mostly working fine except the screen is turning on about every 30 seconds. It then auto-locks just like normal and repeat.
I did lose two screws during my repair, the Y screw in the speaker sensor assembly and one of they Y screws on the battery connector bracket.
I haven't reopened the phone yet to see if anything else looks damaged. I'd like to avoid that so I don't need to replace the adhesive again.
What would you suggest doing next? Can you tell me what component my be affecting the screen this way?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sometimes a faulty LCD with ghosting issues can cause this. It turns on as an effect of 'thinking' the lcd was touched. I have had multiple displays doing all sorts of things by itself.
Try with another LCD - initially only connecting the LCD and not the FACEID flex. See if it turns on now. If it doesn't, try to install the flex cable as well.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kylewd12 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 26
