跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Screen/Digitizer lines issue
Put a new screen and digitizer on and the switch powers up and can see everything but there are vertical lines that are kinda of rippling threw the screen. What would be the cause of this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Max,
Best guess would be that one of the two LCD ribbon cables isn't quite seated fully into its connector. When putting it back together you have to make sure the little tab on either side is butted right up against the connector before toggling the latch to lock it in place.
So my advice would be to open it back up again and double-check those connectors. If they both look good, pull the ribbon cable out and wipe it with 90% or higher concentration of isopropyl (rubbing) alcohol just to make sure there's nothing interfering with the electrical signals. Here are pictures of the cables to check.
Carefully plug them both back in and retest. If it's working, button it back up and enjoy! If not, let us know what you found and we'll see if we can figure out where to go from there.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Max 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 62
总计 772
