跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 个问题 查看全部
GUI Freeze after sleep mode
Hi,
This is my first post because here after searching your and other forums.
I've got 2007 aluminium iMac that freezes up after sleepmode and normal use. The spinning beachball appears and the GUI get's stuck. Only the cursor moves. Only a hard reboot get's the machine online again.
I tried the following:
  • fresh system software
  • checked all firmware updates
  • reinstalled the original ram modules
  • installed a other hdd
  • ran several tools like TechTool deluxe to pinpoint the problem
None of the above helped. I extracted code the following from the Console App. This code is generated after the system freezes up.
23-09-11 17:44:20 kernel ** Device in slot: SLOT--1 **
23-09-11 17:44:20 kernel ** GPU Debug Info Start **
23-09-11 17:44:20 kernel 0x000094c8
23-09-11 17:44:20 kernel 0x000000d6
23-09-11 17:44:20 kernel 0x00000001
23-09-11 17:44:20 kernel 0x00000018
23-09-11 17:44:20 kernel 0x0000d062
23-09-11 17:44:20 kernel 0x00000015
23-09-11 17:44:20 kernel 0x00000000
23-09-11 17:44:20 kernel 0x00000047
Could it be my video card is the cause of this?
Regards,
Benjamin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
''Run Applications->Utilities->Disk Utility->DFA-repair drive'' on your disk drive. Sounds like your HD is failing. Be sure to back up any important data. Also try resetting the PRAM. If this works you could need a new backup battery for the Logic Board.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benjamin van den Berg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,014
