跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
iPhone not charging when turned on, but charges when turned off
Hey all, I found my old iPhone 4, and I used it for a bit, and I realized that I had some very cool and fond memories on the device, I was gonna export the pictures and videos from the device until I noticed that plugging the device in did nothing. It won't charge, but when you plug it in, turn it off, and leave it, it will charge (I did that before I went to work, and I came back after work and I turned it on, and it was fully charged) but plugging it into a computer will cause Windows to say "USB device not recognized" saying that it malfunctioned. And no, the battery works fine, it does drain a bit fast, but no sudden shut down issues, before it broke, 3uTools reported that it had 88% battery health, the battery I replaced it with was also a used one at 85% health, same as the original one, drains a bit fast but no sudden shut downs.
I have replaced the battery, and the dock connector, I grabbed the charging flex assembly from an iPhone that was locked but I did test it and yeah, that phone did get detected and did charge properly, I put it in to the iPhone that has the issue, not only did it not fix it, but now, when I returned the charging flex assembly back to it's original device, that same device now exhibits the same issue; not charging when turned on, charges when powered off, and is not recognized by the computer when you plug it in to one.
Update (47 minutes after this was posted), I left it plugged in, and I have noticed it charges as fast as it would, only problem is again, it doesn't show that it's charging, and it still can't get detected by a computer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
First off, stupid question. Did you check the port on the phone? There may be lint
Second, is the cable bent? Knowing that Apple deprecated the 30 pin, it may be hard to find a official charger. Amazon has 30 pin chargers still being made however
If none of these are the problem, there may be a problem with how the phone charges.
这个答案有帮助吗?
得分 0
2条评论:
I did try different chargers, and considering I have tried a charging flex assembly from an iPhone I have verified that charges just fine with the same cable, that would rule out the charger or the charger port being broken, I wasn't clear though, so there's that.
完成的
Yeah, that may be it. The charger port is dying or the connector itself is broken
完成的
添加一条评论
添加你的答案
Raine Gillingham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 37
