跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
113 个问题 查看全部
Touch bar changed, no signs of life
Greetings all,
Yesterday I've managed to change to touch bar on my MacBook Pro as the old was flickering and drove me crazy. The replacement part I've got matches the P/N of the old one. Unfortunately, after the install the light bar had no signs of life.
I was extra carful with the installation and I'm sure nothing was damaged during the process of installation.
The touch bar option in the menu is no longer available...
Old touch bar P/N: 821-00681-A (1942 075)
New touch bar P/N: 821-00681-A (1842 066)
Flex cable: x1526 (tree line version)
Please suggest where I went wrong or what should I do, I've already doublecheck all the connections.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you sure the issue was the panel Vs the driver board?
这个答案有帮助吗?
得分 0
6条评论:
not sure, but I would expect the same behaviour right? ... I guess the next step would be replacing the driver board.
完成的
@mariolipcik - Depends on what happened and how the display is reacting.
完成的
@danj Original touch bar was rapidly flickering/flashing white with full brightness from right to left, halfway only and still count be used (I was just getting sick from it after a while). From time to time it would stop, but shortly started again. The new touch bar isn't showing any signs of life...
完成的
@mariolipcik - That’s sounds like a driver issue.
完成的
@danj any advice where to get it?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Mario Lipcik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 48
