跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Getting the LCD back in casing
So I just replaced the LCD on an IPOD 4g everything turned out great. The lcd and everything is working fine im just having trouble getting the screen entirely into the casing. I dont wanna force it to much because I dont wanna crack the LCD because its very thin. I feel like when I try to push the bottom of the screen in the top pops out anyone have any tips on this. Thanks in advance :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I cant figure this out I even took out the metal plating and put the LCD on top and it still doesnt seem to wanna fit in there correctly.
完成的
添加一条评论
1个答案
已选择的解决方案
I would lay it down flat on a table face down to make sure the casing wasn't bent then the other two things I would check are that the little speaker assembly at the bottom of the unit is put properly under the lip and second that the metal piece that is affixed to the top of the digitizer is placed correctly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arron Mayers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 457
