跳转到主内容
Repair guides and support for water softening systems.
4 个问题 查看全部
Flow Meter Sensor for Culligan CTM Softener
Hi there!
I have a Culligan CTM Top Mount Softener. I understand that one end of the cable is supposed to connect to the main control board (done that!), but i am having a hard time figuring out what the other end (where the plastic sensor is located) is supposed to go. Any hint will be much appreciated!
  • Kevin
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
HI @kevinlee38086
Here's the manual that may help.
See p.5 for the location of the flow meter. Presumably the flowmeter sensor attaches to it somehow
Usually flowmeters are a turbine located inline with the incoming (or outgoing) water supply and it rotates when the water flows through it. One of the blades of the turbine has a magnet attached to it. When it passes the sensor the magnet operates a reed switch in the sensor, which sends a pulse to the control board. Basically the control board counts the number of pulses it receives so it knows how much water has passed through the flowmeter i.e. no flow, no pulse
Did you get the sensor in a package with the sensor's part number on it?
If so the manual has a parts diagram with a parts list which shows the location of the parts as well as its part number. You may be able to locate the sensor location that way.
It also shows the connections on the control board as well
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kevin Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 19
总计 122
