Quadcast S not showing up in Device Manager (Win 11)
I have had issues with my ~2 year old Quadcast S for a bit now, nothing that prevented it for working though. For the past week the microphone had an error show up when plugged in, nothing I couldn't fix, I uninstalled the "unrecognized device" from Device Manager, reinstalled USB Composite Devices and it always started working. Today, the Quadcast S isn't even showing up in Device Manager.
Things I've tried:
- Reinstalling Everything USB Related in the Device Manager (showing hidden devices)
- Reinstalling Everything Audio Related in the Device Manager
- Every other USB Port
- Testing the original cable on another device (can charge and transmit data)
- Using a USB-C to USB-C cable
- Heating it up (as suggested on Reddit by another User with the same issue)
- Changing Power Settings
Other Notes:
- The Device isn't showing up in Device Manager
- The RGB Lights aren't on
- There is no connection sound made by Windows when plugged in
- There is no pop-up by Windows when plugged in
- I use NVIDIA Broadcast
- All the drivers are up to date
It's as if the microphone doesn't exist. Help is appreciated, thanks!
2条评论
Been awile @jayeff it does work on another pc but not mine any ides?
由 Ennis M 完成的
@ennism
Do other devices work on same USB port in your PC?
Any problems detected in Device Manager on any other USB devices? - check in Device Manager - Universal Serial Bus Controllers and ensure all the devices listed are working OK as far a Device Manager is concerned i.e. no red cross, no yellow exclamation marks and also right click each USB entry - Properties - General tab - Device status box
由 jayeff 完成的
