跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
476 个问题 查看全部
iPhone 11 screen laggy after screen replacement
The iPhone 11 screen is very laggy and sometimes registers pressing as holding, it works slightly better with low brightness, but it rarely works without any problem after turning it off and on again. I didn’t have a problem with a „reproduced” screen, but when it broke, I’ve cheaped out and bought a worse screen because it had some good reviews. Can the screen quality be the issue in this case? Also, heavy games like Wreckfest work perfectly fine without any frame rate drops whatsoever if it has to do anything with the „lag”.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It sounds like a display issues - even good review LCD's can be faulty. My experience is that after-production quality control is in best lagging or completely absent.
When replacing a screen, always order to pieces, and try the other if the first doesn't work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lastunio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 43
