跳转到主内容
加入维修社区 - 创建账户
发布于9月16日,苹果公司的 "小型 "旗舰智能手机,其拥有6.1英寸ProMotion OLED,三镜头后置摄像头系统,5G,以及围绕前置摄像头和顶部传感器新设计的 "灵动岛"。iPhone 13 Pro的继承者。
hello I have iPhone 14 keeping restarting
hello i have iphone 14 keeping restarting
panic(cpu 2 caller 0xfffffff05dc10fdc): SMC PANIC - ASSERTION FAILED: target/d27/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40
S.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0
F.sensor array 0 is 0x0
- Misc(2) OUTBOX1 not ready
RTKit: RTKit-2413.42.1.release - Client: AppleSMCFirmware-4257.42.2.d27.REL
!UUID: fab53dca-5d4c-3354-a473-f8e57aa561cc
Time: 0x000000010da8c27c
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@arvind4366, It looks like we haven't got that particular error logged in our Kernel Panics Wiki page yet, but over on repair.wiki, they've got a listing for it.
That's a curious one, as it's not a failure I've personally seen before; the only time I've run into a charging coil failure has been from someone who was doing a rear glass replacement and damaged it.
Anyway, I don't know what might have gone wrong with your phone, but at this point the best advice I can offer is to replace the wireless charging coil and see if that fixes the problem. There don't appear to be any guides available to show you exactly how to replace it, but I'm guessing if you remove the rear glass cover it's mounted on, it should be pretty straight forward to figure out how to replace it. This guide will show you how to remove the rear glass.
iPhone 14 Rear Glass Replacement - iFixit Repair Guide
Luckily, you can also buy that charging coil directly from iFixit as well as other sites like Amazon, eBay and AliExpress.
iPhone 14 Wireless Charging Antenna
Of course, the other choice is that you could replace the entire back panel and thereby sidestep the entire issue of how to replace the coil by itself. You can find those on Amazon and other places. If you go this way, make sure the part you choose specifically says it comes with the charging coil. I think this one fits the bill.
Amazon.com: Rear Back Glass Replacement for iPhone 14 with Middle Frame and Side Key : Cell Phones & Accessories
Good luck and let us know how it turns out!
Note to @flannelist: I've added the 0x40 0000 code to the Kernel Panics Wiki page since it's documented on repair.wiki now.
Replace a damaged or malfunctioning internal inductive charging coil in an iPhone 14.图片
产品
$24.99
这个答案有帮助吗?
得分 1
2条评论:
as u said i have removed backglass n just refitted problem seems to be fixed.. lets see i will keep for somemore time playing a nice songs n check , thank u so much @Jerry Wheeler
完成的
@dadibrokeit Duly noted :)
完成的
添加一条评论
添加你的答案
ARVIND 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 1,472
