跳转到主内容
The Xiaomi Redmi 9A is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G25.
Can this phones memory be extended
Phone keeps say memory is almost full
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @deanharty
You can increase the storage capacity of the phone up to a maximum of 288GB by inserting a 256GB micro SD card in the phone to add to the existing non removable 32GB internal storage.
This is the maximum amount of removable external storage the phone supports. You cannot increase the amount of internal storage as it is hard mounted on the systemboard.
Note: when it says "memory is nearly full" it means storage i.e. where you store your images, documents, files as well as where the Android Operating system is installed etc and not the actual "memory". That is used for the operating system to function as it is only temporary storage that is used as required. Your model has 2GB of memory - this cannot be increased.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dean Harty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 508
