跳转到主内容
加入维修社区 - 创建账户
Flipper Zero是一种多功能的多工具设备,设计用于黑客攻击、调试和试验各种电子小工具和系统,如传感器、接收器和其他电子组件。
Flipper Zero. Stripped the screws a bit. What do I do?
I used a small metal screwdriver when trying to replace the housing shell and I think that it was stripped a little, but not as much. I don’t want to continue to try to unscrew it with the risk of completely stripping it. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
If you are un-screwing, usually the problem is using too big or too small of a screwdriver. Get the size that is big as possible that fits and press in as hard as possible when unscrewing. I don't yet have a flipper, so I can't recommend a screwdriver. ( but plan to buy one soon, such an amazing device)
这个答案有帮助吗?
得分 1
1条评论:
The proper size is PH0
完成的
添加一条评论
First get the screw out and take them into a hardware store or electronics parts place and have them get you placements and then reinstall using the proper sized screwdriver
这个答案有帮助吗?
得分 0
添加一条评论
Try soldering iron and twist with your screw driver
这个答案有帮助吗?
得分 0
1条评论:
That’s a last resort though. 🫤
完成的
添加一条评论
添加你的答案
KingCool 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 783
