跳转到主内容
Repair and disassembly information for Samsung's Galaxy A32 5G Android smartphone, released in February of 2021.
85 个问题 查看全部
Can I replace the screen more easily if the frame is not broken?
I have an A32 5G with a broken screen that has come loose from the frame, but undamaged frame. The guide (https://www.ifixit.com/Guide/Samsung+Gal...) says that replacing just the screen is a different process, would it be a simpler one, or am I better off just removing the frame as well and replacing the whole assembly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Darohan,
I personally find replacing just the screen is far simpler than replacing the screen and frame, although you do have to be more careful - especially with OLED displays.
On most android phones you just need to heat up the screen with a heat gun, hairdryer, heat plate or something similar to soften the adhesive until you can insert a pry tool under the display to remove it. However as in your case the display has already come detached, you can completely skip this step : )
From there, you can just apply new liquid adhesive such as E8000 to glue the new display in place.
Hope this helps, let me know if you have any further questions : )
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darohan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 46
