跳转到主内容
Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
67 个问题 查看全部
Airpods not charging in the case
So my airpods are not charging in the case but they still connect to my phone and even if i charge the case i doesn't charge the airpods. They've been discharged for over a week and i dont know what to do. Does someone have a solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
But the case seems like it's charging or is acting charged?
If neither of them are charging this might be a firmware issue. Apple's firmware update solution is sort of silly. The process is effectively:
  1. Put Airpods in the case.
  2. Charge the case. Make sure the lid is closed.
  3. Leave them on the charger near a paired device. Apple suggests twenty minutes, but if you can spare the time leave it for an hour.
You can also try resetting them. This will return them to factory settings.
  2. Close the lid and wait thirty full seconds.
  3. Open the lid then press and hold the button on the case for fifteen seconds or so.
  4. The light will blink amber, then white if you are successful.
I would also give the case a good inspection. See if there is anything stuck in the bottom of the case. Otherwise, a replacement case would be your best bet.
这个答案有帮助吗?
得分 1
添加一条评论
I would get a replacement case from apple
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel Caisse 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 53
