跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
Battery Flex Cable Error
When repairing screen , I think I accidentally removed the battery flex cable fully and now cannot get cable to stick fully back where it belongs … laptop will not power on … what adhesive would I need for that? Thanks
Update (11/19/23)
I tried to tape it down but doesn’t work … I just presume this is what is wrong with the mac… as I felt it was only thing that went wrong during the screen replacement process … I also didn’t screw out the screw in that battery strip area… but that wouldn’t affect the computer would it ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you add some pictures to your post? By the sounds of it, we'll need to see what you're looking at the give the best advice.
完成的
[image|3142725]
[image|3142726]
Where the flex cable connects on the right side , I believe there may be a problem. Is there any other reason why laptop would not turn on?
完成的
添加一条评论
1个答案
最有帮助的答案
Ah! I see! This is an easy fix. So this cable is a bit weirdo. It goes in the other way. So rather than it being a straight shot between the two connectors, the one on the battery board side curls around, and the connector goes into the back side (the edge near the speaker, rather than the edge near the other batter connector).
You can tell in this picture how it's supposed to connect. Adhesive not necessary. Cable should just lock into place like the other end.
这个答案有帮助吗?
得分 2
1条评论:
Hi I did this and laptop still not turning on …. When I was first connecting I smelled something off? Perhaps a fuse blew?
完成的
添加一条评论
添加你的答案
Tolu I.D. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 149
