跳转到主内容
加入维修社区 - 创建账户
也称 PS2 ,是索尼于2000年3月在日本首发的第六代电视游戏主机。当年稍后时间登陆美国市场,机器型号为 SCPH-30000。维修这款设备只需用到常见的工具,但维修过程可能会有点难度。
component cable connection setup
I purchased a component cable for ps3 for my playstation 2.
https://www.amazon.com/dp/B07VCT41QV?psc...
The cable is connected to my playstation 2 via a video switch
https://www.amazon.sg/GE-73344-Switch-El...
My question Is my compoent video switch set up correctly?
I didn't know that the switch only has 5 ports, but the compoent cable has 6 plugs. Right now, I only have the red and white audio connected along with the yellow connected in the green port.
The playstation 2 is set for compoent cable in the menu. The cable replaces an oem cable that broke. I'm using a compoent cable for ps3 since they are easier to find and cheaper in price then a ps2 compoent cable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
That amazon cable for the ps2/3 has both component and composite, also known as rgb and rca/av, Your switcher only supports rgb video, which you seem to have confused with rca. You need to plug the green, blue, and red from the ps2 into the green blue and red ports on the switcher. You have audio plugged in correctly though.
这个答案有帮助吗?
得分 0
1条评论:
I did the switch. I have never heard of compoent and composite in the same cable.
完成的
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 244
