跳转到主内容
Sony WH-1000XM4 無線降噪耳罩式耳機維修拆解資訊。
20 个问题 查看全部
No sound from the left side.
Hello, I bought Sony WH-1000XM4 headphones in unknown condition. It turned out that the right side, the speaker and the touch panel were fully functional. On the left side, the buttons, NFC and indicator light work. The only biggest problem is that there's no sound from the left speaker. I tried to connect to the computer via aux and again, sound could only be heard from the right side. What could be causing this problem? I would be very grateful for your answer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi,
I've had the same thing happen to my headphones. What I did was I wiggled the left earpiece around until the right sound turned on; It would only turn on if it was placed in a specific way so every time I use them i need to wiggle it. If you want to fix it permanently, you could try opening the left ear cup and checking if anything is disconnected, because that is usually the problem. Hope I helped!
这个答案有帮助吗?
得分 0
2条评论:
I opened it and checked if anything is disconnected before that and no, everything seems to be alright.
完成的
Im not sure then. Sorry.
完成的
添加一条评论
try diffrent songs or sound tracks and see if there is a change.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
thezoneofcum 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 26
过去 30 天: 82
总计 1,402
