跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
The screen does not work properly when I put down the screen
I have got an issue with Iphone xr. I replaced the screen and tested it before I put the screen down to the frame.
Everything worked fine. But when I put the screen back to the phone, touch did not work and sometimes had partial dim backlight. I tried a couple of screens with the phone and found it they work all the same.
I had to cut one of the little things on the bottom of lcds which the screw passes through to get the screen sit properly because there was one pentalobe stripped.
Has anyone been through this issue before or know how to fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Which screen are you using to replace the old one. If its an off brand one that could be the problem. People sell cheap LCDs that most of the time dont work and are crappy. Make sure you have a good one, if you dont then you should replace it.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the answer. I am quite sure I am using reliable LCDs as I have not got the issue with other XRs before.
完成的
添加一条评论
添加你的答案
Jake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 21
