跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Black screen after replacing flex cable. [SOLVED]
[THE PROBLEM]
I ran into an issue in the shop where after replacing the Flex cable every screen I tried was black. The iPod wouldn't even beep when plugged in.
Since I googled the tar for a solution, and couldn,' find one, I'll post what I found for anyone else with the same problem who hasn't been able to find a solution.
The solution is moved below, to the answer so that it can be cleared per request.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Please use the last paragraph as an answer and accept it to clear the question.
完成的
Thanks for letting me know guys, I did as you suggested.
完成的
添加一条评论
1个答案
已选择的解决方案
[HOW TO FIX IT]
I covered the circuits around the flex cable and de-solder it then cleaned up the pads and soldered on the new flex.
Not adhering to my own soldering instructions, of course I got in a rush and did this without de-soldering the + terminal on the battery first.
In my case, I went back and disconnected the + terminal on the battery and soldered it back on. The black screen went away and the iPod kicks up just fine.
I hope this helps fellow techs that may have found this.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Country Computer Service 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 11
总计 3,304
