跳转到主内容
非苹果电脑键盘维修指南。
244 个问题 查看全部
Need tips cleaning and repairing corrossion caused by liquid damage
I spilled some soda on it and now the "Q" key got corroded so bad it and "Tab" key isn's funtioning anymore.
Tried to clean it with white vinegar and IPA but it doesn't seem to be effective, and also looks like the pads are also lifted off.
I also tried to scrape the corroded gunk but somehow it refuse to come off.
Can someone give me some tips to bring it back to life (retracing, conductive adhesive,...)? And is that true that the upper side (side with the key caps) are for key collumn/row and vice versa because i'll probably have to bridge this switch.
P.s. I'm new to fixing boards so if you can be as detail as possible that would be much appreciated. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You must very gently take off every letter and with clean qtips clean it changing the qtip often. You can use a very little alcohol on the parts that won't come up with a dry one. Check the inside of the cover and letters as well
Update (11/15/23)
Also, any damaged wires have to be re-soldered on(new ones) if you aren't confident in your abilities to do this you can watch videos on this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Capital c on blue background 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 16
