跳转到主内容
Introduced in 2011; identified by the serial number 1d16dx.
3 个问题 查看全部
Won't turn on, only charging led on
The computer does not turn on, only the charging LED, but when you press the power button, the charging LED turns off, after a few seconds, the charging LED comes back on. And I have already tried to do a hard reset, but it doesn't work. helped. Any advice to find out what the problem is?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Could just be a is defective battery.
Try taking out the main battery out and just plug in the charger.
Click here to remove battery
Does it work now?
这个答案有帮助吗?
得分 1
1条评论:
It does not work. This had happened before, and what worked was leaving the laptop without battery for a week. I would like to know the cause or how find it, and solve it.
完成的
添加一条评论
添加你的答案
Armando Rodriguez Medina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 21
总计 55
