跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
MacBook A1398 2015 Loud Fan
Hello
I have an A1398 2015 MacBook Pro 15" that has the right fan turning at high speed and making a lot of noise. I have cleaned it, removed the heat sink and replaced the thermal grease, replaced both fans but the noise is still present. Does anybody have any advice? The problem is not related to the hard drive as I have swapped it out but still have the same problem. Apple Diagnostics reference code PPF004 and PPF003. Thanks for your help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
check the fan itself, if you can try and replace it to see if it resolves the issue
这个答案有帮助吗?
得分 0
1条评论:
The fans have already been cleaned with no success and then replaced with new fans. The problem remains the same.
完成的
添加一条评论
添加你的答案
Tonja Halley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 59
