跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
Battery shows lightening icon, but it not charging
Hello,
my old iPhone 11 Pro Max, suddenly did not charge anymore....
I have purchased a new battery, bit still it does not charge... the battery came charged and I can see that when I plug the power cable, the lightning icon in the battery icon is visible, but the battery does not charge... it actually "decreases" the percentage...
it seems that the motherboard "sense" the power cable, but there is somethgin preventing the battery to re-charge...
having already replaced the battery, so I can exclude a battery issue... what next?
what would you try to change/try to assess?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Ivan,
Next thing I'd try would be a wireless charger. You can pick up an inexpensive one just to test the charging. If it works, that would tend to eliminate the charging circuitry on the motherboard and the battery as sources of the problem and instead point to the charging port flex cable assembly as the likely culprit.
iPhone 11 Pro Max Lightning Connector Assembly Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ivan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 27
