跳转到主内容
New LCD Install - No Display
I've got a Mid-2009 Macbook Pro 13, and I just installed a new LCD after accidentally cracking the old one. Before the install, the old LCD would still show a white screen, and I could display the screen on an external monitor. After the replacement, the NEW LCD would simply remain blank when I turned on the computer (I can still display on an external monitor). I swapped the LCDs out again, and the old (cracked) one will still light up as it did before. I then reinstalled the new one, yet it still does not display. I've checked the connections on the logic board, and I don't believe I have an problems there, and since I can display and operate the computer using and external monitor, I don't think the Logic Board itself is damages either.
Any ideas what might be wrong? Do I need to do anything special to make the LCD register with the computer (wouldn't think I would need to). I'm thinking the NEW LCD was DOA and that I need to send it back, but thought I'd reach out first.
Any suggestions are welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
it should be the same number at back of your original led screen
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Yea that screen was DOA -if you haven't already contact the vendor for a replacement.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Josh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 623
