New Power supply not working
Hi l replaced the power supply in a friend ps4 pro the old one blow up ( roaches) I put in the new power supply I press the power button it beeps no light I press the power button again it beeps the blue light turns on for a second then off and it repeats this pattern any help would be appreciated.
What sort of symptoms was it experiencing before you replaced the power supply?
Power supplies going bad can also spell bad news for other components depending on how it failed.
由 Alisha C 完成的
check that the 12v pins on the motherboard are straight, also if you removed the motherboard you could have over tightened the heatsink clamp
由 daniel 完成的
