跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
20 个问题 查看全部
Why is the fan blowing very hard?
It was my first time opening up a console because the LCD screen was damaged and wanted to replace it. After I was done replacing the LCD screen I accidently tore the fan ribbon cable during the process and when putting everything back together the fan was blowing very hard (didn't do that before). I am inexperienced but I assume it is because of the tear in the fan ribbon cable. Everything is working fine on the console. I just want to know if I have to replace the fan or if it is something else. I would appreciate the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I replaced the fan but is it suppose to spin right away or will it spin if it reaches a certain temperature?
完成的
添加一条评论
1个答案
已选择的解决方案
Could definitely be due to this tear. The bit that’s torn could be the part the gives information about how fast it should spin to the fan. Without that data, it just spins full bore. Sounds like new fan is definitely the way to go.
这个答案有帮助吗?
得分 1
2条评论:
Thank you! I ordered a new fan and now I have to wait and see if it will fix the problem. Thank you again for the help!
完成的
It worked thanks for the help!
完成的
添加一条评论
添加你的答案
Potato 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 190
