跳转到主内容
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
Connecting a Dell Optiplex Moniter to Mac Mini i3 A1993 2018
In this case I am sure that the Mac i3 is functioning and that the Dell Optiplex Moniter is also functional; there is no USB port on the Moniter.
Previously I had an Apple A1347 Mac Mini running with a Vodafone Router and I am using the same cables now, but there is no responce from the Moniter, the Dell Self Test only appears and moves around on the screen.
The ethernet cable is functioning on my PC and I also use a Net Gear Prosafe GS105 with cross over cables on the PC.
I now have a Shell Energy Router DGA0122NLK and I am not absolutely sure if I am using the correct ports on it as not much details were sent, but it works for my Viglen Genie PC.
What I realy want to do is get the Mac Mini, Coffee Lake running the PC is only a server computer in this situation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You appear to be dancing around talking about USB which is not involved in hooking up your display. Next you get into Ethernet and a router which again have no bearing on hooking up a display.
Your Mac has a combo port! The Thunderbolt port also supports mDP connected displays or a mDP to HDMI or other display interface.
As to making it a headless server or running Windows let’s first get the system working as a Mac, then you can get to these issues.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Savlen Dempsley 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 149
