跳转到主内容
Professional audio equipment refers to high-quality sound devices and systems designed for use in professional settings, including recording studios, live sound reinforcement, broadcasting, and various other applications.
57 个问题 查看全部
mackie srm450 v2 keeps shutting down?
The amp in my Mackie srm 450 keeps shutting down. I cna power it back up by turning the power switch off then back on and it is fine for a little while then it does it again. Any ideas[to me it sounds like a relay]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @oliverconway,
According to p.8 of the user manual there's a red LED thermal indicator (Item #5) on the back panel.
Check if it is on when the amp turns off.
If it is then you may have to open it up and check what's getting hot or at least what's looking heat stressed etc.
Here's the schematic that may help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
oliver conway 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 34
