跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
20 个问题 查看全部
pioneer mvh-s622bs notification
I have a pioneer mvh-s622bs and I keep randomly getting a "Connection notification with main unit: connect to main unit?" Notification on my phone while my car off. Why and should I worry about my radio turning on while my car isn't?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @wilburchfield,
If the phone is connected to the radio using Bluetooth (BT) then if you're receiving notifications on the phone and the car is >33' (10m) from the phone then the Pioneer app? in the phone may be sending the notification, because the car is out of range and presumably the radio is turned off, so it can't connect. You won't be receiving anything from the radio
Perhaps check the settings in the app or try turning off BT in the phone and see if the notifications stop.
Quick way to tell depending on the time interval between the notifications is to sit in the car with the unit turned off and check if you still get the notifications and check if the radio has turned on or not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wil Burchfield 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 57
