跳转到主内容
加入维修社区 - 创建账户
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
Display Covered in Horizontal Lines
Hello,
I was given the task of fixing a Thunderbolt display at my university. If I can fix it, I get to keep it, so I accepted the challenge. First impressions of this display weren't too bad. The issue that it has however, is that when plugged in, all over the screen is a bunch of horizontal lines. I was told before testing it that when it was last powered on, there were only sections of the display that had lines, but I'm not certain if that was describing the same defect I was seeing on the display.
Either way, everything else seemed to work perfectly fine, so today I partially disassembled everything to see if there was anything clearly wrong. I can't remember if someone has already tried working on this unit before, but it looked very tidy. Everything looks intact, and visually the power supply and logic board looked good.
So, I'm not so sure where to start, I just know my issue may lie in either the logic board or the panel itself. I'm inclined to say the panel is flaky given the other issues I've seen here.
If anyone has any insight as to what I should try to do to troubleshoot, it would be greatly appreciated!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your issue is within the display assembly, technically within the T-CON board. I would inspect the caps within the T-CON it might be a simple fix other wise it’s time for a new assembly.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the reply! Tomorrow I'll try and see if I can dig into the panel and inspect the T-CON.
完成的
添加一条评论
添加你的答案
Jeff'sTech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 246
