跳转到主内容
Repair guides and documentation for the Google Pixel 5a with 5G smartphone. Released in August 2021.
How to check if it is original phone
i know that way of repair then put imei. it doesnot work any other way
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@team06 Here's one way to check that the device is unmodified and from a reputable manufacturer:
  1. Open the Play Store app. If you need to, you can sign in using a throwaway account (Don't sign in with a Google account you use for important things)
  2. Once you go through the process of setting up the Play Store, select your profile in the top right corner
  3. Select "About" and look what it says under "Play Protect Certifocation". If it says "Device is certified", you're good. If it says "Device is not certified", the phone is fake or has been modified.
这个答案有帮助吗?
得分 0
2条评论:
thanks for the guidance.
完成的
@team06 You're welcome
完成的
添加一条评论
添加你的答案
Team06 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 256
