跳转到主内容
The Nikon Coolpix A900 is a compact user friendly camera, with an adjustable screen that makes it easy for different camera and video angles.
7 个问题 查看全部
Camera is on but not lcd picture why
Camera in on but not lcd picture why
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @banamalimohanty ,
Try taking some pictures (I realize that you cannot see what you're taking) and then download them to a computer and check if they're OK or if they are just black images.
If the pictures are OK then it is either a failed screen backlight (faulty backlight power supply from motherboard, a loose backlight power cable connection from the screen to the motherboard (see smaller flex cable in this image of the LCD screen (supplier example only) or most likely a faulty screen.
If the pictures are just black images, then it could be a faulty motherboard. If it were only a faulty cmos sensor in the lens then you would still be able to view the camera settings menus on the screen.
If it is determined that the problem is the LCD screen here's the ifixit Nikon Coolpix A900 Monitor Replacement guide that may help. Search online for Nikon Coolpix A900 LCD screen to find suppliers that suit you best.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Banamali Mohanty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 56
