跳转到主内容
加入维修社区 - 创建账户
The first in the Cyber-shot P series, this 5 mega pixel camera was released in 2003 as a great camera for the intermediate photographer.
I can't take pictures it's showing Format error
I can't take pictures because it's showing Format error
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It can possibly be four different factors:
  1. Your SD card is formatted in a format that differs from the one that your camera is able to use. In this case you'll only need to format it to FAT32 on your PC (you can find plenty tutorial on this website or on YouTube).
  2. Your SD card has an architecture impossible to read by your camera. Check that your camera supports the type of SD you're using (may it be SDHC, SDXC or others)
  3. Your SD card became corrupt and the camera isn't able to read or write to it because of this. If this is the case you'll need to buy a brand new SD card;
  4. Your camera has a faulty memory reader unit, or worse, your camera could have a faulty CPU. If none of the things I've listed before is the problem, you shall buy a new camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prem Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 193
