跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
How can I fix the plastic "chin" under the display?
I had a random staple that wandered onto my macbook which I didn't realize until I went to close it and heard a crack. The screen and everything looks good but the plastic in the bottom right seems to be cracked. Is there any way to fix this without having to replace the whole screen?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First it’s glass not plastic! Be very careful as just behind it is the ribbon cables which drive the display and camera system. It doesn’t take much to damage them and once damaged it’s time for a new display!
Ok now that I’ve scared you, using a thin knife careful lift off the loose broken pieces then using a hair dryer being careful to only heat up the plate (use some foil to protect the keyboard and screen) again use the knife to just grab the edge of the smaller segments. I use some good sticky tape to make pull to help lift off the bigger pieces.
Sadly Apple hasn’t published the newer M2 model repair manual yet. Here’s the M1 version which I’m suspecting uses the same basic parts M1 13” MacBook Pro sadly the chin plate is not available from them but I think you can still find them online as I’ve gotten them before.
这个答案有帮助吗?
得分 1
2条评论:
@dan. it is not glass, it is plastic...
完成的
@thomasheap - Apple started off with Glass, then switched to Plastic. I’ve mostly seen broken Glass units.
完成的
添加一条评论
添加你的答案
krankxl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 538
