跳转到主内容
加入维修社区 - 创建账户
A 13-inch "2-in-1" laptop with a 360-degree hinge that allows it to convert to a tablet-like form factor.
My hinges aren't working
My hinges popped out of place the other day...I mneed to check them
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @carol29331
Here's the service manual taken from this support webpage for the laptop that will help.
Go to p.50 to view the necessary pre-requisite steps and then the procedure to remove/replace the display assembly.
On p.51 it shows the hinges. You need to check whether there's a problem on the lid side of the hinge or the base side of the hinge as sometimes the hinges themselves may be OK but they may have either come loose from one side or perhaps the hinge screw mount may be broken, which would require either a new lid or base assembly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 171
