跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
iMac won't turn on. No LEDs light up. iMac 27" Late 2015
Mac was working fine until one day - No response to power button.
Removed screen and plugged into power - None of the 4 LEDs light up. Tried shorting the leads where power button plugs in to the PSU - still no response.
I do not have any special electrical Dx equipment like voltmeter, etc. How can tell if it's the Power Unit or something else
iMac 27", Late 2015, Model: A1419 - EMC: 2834
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would start at the power outlet using a outlet tester to make sure its correct wired. Sometimes I've seen power supplies damaged by miswired outlets and bad or no grounding doesn't help matters either!
You don't need anything fancy, I have one of these AC Outlet Receptacle Tester
Next you should inspect the back of the systems connection where the cord connects. Sometimes I find corrosion or arcing has damaged it and I often try a spare cable to be sure the cable its self wasn't bad
Then we need to review the systems onboard diagnostic LED's and as you've already noted the LED's are not lit and shorting across the power switch din't offer any life, we need to go back and verified the AC power side is good then the issue is likely the power supply
It's not that uncommon for them to fail. The bigger risk is a power surge or lightning hit which damaged them iMac Intel 27" (Late 2012-2020) Power Supply Do make sure you have a good surge suppressor or better yet a UPS
If you do find the outlet has issues then you'll need to check the buildings wiring and also inspect the breaker panel making sure the panel is correctly wired and verify the grounding connection for the building is intact. Older building often have poor ground for the grounding rods rotting out or corrosion at the clamp.
Replace the power supply for a Model A1419 Late 2012 to Mid 2017 or Model A2115 Mid 2019 to 2020 27" iMac.图片
产品
$99.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eogold 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 246
