跳转到主内容
微星所制造的笔记本电脑的维修和支持指南。
269 个问题 查看全部
Where can I get a replacement LCD display for a MSI Z16 Creator Laptop
I have MSI Z16 Creator a11uet laptop where the digitizer is cracked, not sure if it can replace separate, I haven't had much luck finding a replacement, does anyone know where to get one or a good site that sales LCD displays? I have tried allexpress and ebay.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @andy45292,
Best option may be to disassemble the laptop and remove the LCD panel.
Not sure with MSI but with others e.g. Asus, HP, Lenovo there's usually a part number somewhere on the back of the panel either on a sticker or printed on it.
Don't confuse the part number with the screen manufacturer's make and model number which may also be onthe back of the panel. Although sometimes knowing that can be helpful as well when looking for a replacement. (LCD screens are usually made by specialist manufacturers and not by the manufacturer of the laptop).
If there is a part number, search online for the part number only as the screen may be also used in other models but may not be listed with a supplier as being compatible with your model even though it is.
Just what I'd do
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your input on checking the LCD panel model instead.
完成的
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 66
