跳转到主内容
The JBL Flip 6 is a small portable Bluetooth speaker, released in September 2021. It is equipped with a woofer and a separate tweeter, and dual JBL bass radiators. This Speaker comes with an IP67 and up to 12 hour battery life. Model: TT
7 个问题 查看全部
Speaker will not turn on and will not charge
I bought my speaker around April of this year. I sometimes use the speaker. When using the speaker it all of a sudden stops playing music and Now it will not turn on and will not charge when plugged into a charger. Any fixes and potential causes on why it wont preform?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
When this happens the most common cause is the battery just being dead, this can happen for a variety of reasons such as excess heat (being left in the sun) or just general use.
It could also be the charging port however if you get led indication that the charger is working then you can probably rule that out.
You can replace the battery but that may be a very involved process due to how tight and sealed these products usually are,
However sometimes people have luck leaving devices like these on charge for a while for it to randomly come back to life but I wouldn't get your hopes up doing this.
这个答案有帮助吗?
得分 1
添加一条评论
I get a broken flip 6 yesterday with the same problem. I took out the board and find out that all caps near the battery was shorten to ground. There was a line of 4 smd caps and the third one was short to ground. It was also slightly discoloured. Im removed from the board. I dont have any replacement for this cap and reassembled the flip an now its working great. I also ripped the bluetooth antenna and replaced it with a nintendo ds antenna. I hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JhonnyBois 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 57
过去 30 天: 188
总计 764
