跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
intermittent f6 code flashing on display.
Hello,
I get a f06 code on the washer when I run a complete wash cycle. I can usually run a rinse and drain cycle. I read the f06 post and tried unplugging and replugging various connectors on the CCU and MCU. I suspect a failing part, possibly a speed or rotation sensor. Where are these sensors?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
9条评论:
Hi @mron,
What is the model number of the washer?
完成的
It's an elite quiet pack 4
完成的
@mron
The model number would help to ensure that if parts are required that the correct part can be found.
完成的
110 45972400
完成的
110 45972400
完成的
显示更多的4条评论
添加一条评论
1个答案
此回答最初是针对另一个问题
Hi @mron
There is no balance sensor in the washer. At least there's none shown in the parts list for the washer.
Intermittent problems can be hard to find so perhaps try checking the connections between the MCU and the drive motor to see if they're all OK i.e. not loose, corroded etc.
Here's the tech sheet for the washer that may also help. On p.8 it describes how to check the windings for the motor, just in case one winding is not within spec or is on the limit of what may be acceptable to the MCU.
这个答案有帮助吗?
得分 0
1条评论:
The tech sheet is very helpful! thanks
完成的
添加一条评论
添加你的答案
Ron Moreland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 164
