跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Slow loading and operation
Slow loading and operation after battery replacement
Update (10/23/23)
I don’t think it is the drive. It happened after I replaced the battery with one I ordered from Amazon. I may have damaged the trackpad to board cable in the process of prying the glued battery because that flat cable runs under the battery. It is super slow to start up and lagging badly on every click to select something
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@walter82849 - I would see if the onboard diagnostics offers any clues. Restart your system and press the D key to enter. Let us know what it tells you.
Mac startup key combinations
If your trackpad or keyboard is having issues and indeed the cables could have gotten damaged. Post a few pics where you think the damage is maybe we can guide you on how to fix things.
这个答案有帮助吗?
得分 2
添加一条评论
Have you tried and made sure the drive isn’t going out and is it ssd or hard drive ?
这个答案有帮助吗?
得分 0
2条评论:
You can also Google what help you need also
完成的
@justinedge74285
Advising the OP to Google for the answer is not what ifixit is all about.
People come to this forum for advice that will help them, not just to be told search on Google.
If necessary posting links to information found online, relating to the problem as an addition to your answer to further explain how to fix the problem is the better way to go.
Moderator
完成的
添加一条评论
添加你的答案
Walter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 138
