跳转到主内容
加入维修社区 - 创建账户
space bar key is working
While cleaning, I removed the space key but it accidentally got detached from its hinge. Although the hinge wasn't damaged, I noticed that there was a gap in the key after reattaching it, which required me to press it harder each time to make it work.I opened a space key to clean but it got detached with its hinge the hinge was not damaged but when I attached it back there was a gap in the space key as I had to press it harder to work every time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Often an Apple Store can pop the Space Bar back on, if the clips are damaged they can also replace the part/S as needed.
I would try them first as it’s often done for free. Going to a good independent Mac repair shop might take a bit of time and unlike the Apple Store who will often do it for the good PR the independent needs the income.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mukul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 139
